[solved] Custom Arrows For Leaders
seasdes
Senior Member
Post by seasdes » Thu Sep 15, 2022 7:54 am
Is there a way to use custom arrows for leaders? In some software this is possible.
Just wondering.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Custom Arrows For Leaders
Post by Husky » Thu Sep 15, 2022 8:19 am
No, not really. The only thing what you can do is manipulate the Arrow size within the Property Editor
seasdes
Senior Member
Post by seasdes » Thu Sep 15, 2022 8:50 am
Thanks Husky
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: [solved] Custom Arrows For Leaders
Post by CVH » Thu Sep 15, 2022 3:43 pm
seasdes,
Like all dimensions and in final stage one can always Explode (XP) them and apply your own theme ... :wink:
seasdes
Senior Member
Post by seasdes » Thu Sep 15, 2022 11:53 pm
seasdes,
Thanks CVH. I suppose that I could apply the leader without an arrow & then apply a block with the required theme (arrow).
Other CAD packages give me an option to apply my own arrows (blocks) as leader arrows. See attached.
2022-09-16_084853.pdf
(5.33 KiB) Downloaded 194 times
Anyway, this is not a deal breaker - but a nice to have.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Post by CVH » Fri Sep 16, 2022 12:36 am
In essence that is a Polyline with a Block Reference at the end. :P
Without an arrow the Style Properties have no further influence.
The difference would be that the Polyline is called a 'Leader' when created as a dimension.
And filtered as 'Leader' or as 'Dimension'.
I both cases you end up with 2 entities. :wink:
Another trick ... Sometimes I explode a Leader to re-use the 3-point Solid entity resulting from this. 8)
