[solved - Feature Request] Open Drawings on Layout Block by Default
zilmosantos
Post by zilmosantos » Wed Aug 10, 2022 1:21 pm
Sirs, please, is there a way to do this? As the layout block contains the drawing sheet, the number, the viewports, it's the presentable part of the drawing.
Re: Open Drawings on Layout Block by Default
Post by Husky » Wed Aug 10, 2022 9:29 pm
No, at least not to my knowledge. Question: If a drawing contains e.g. 10 layout blocks how would QCAD possible know which one needs to be opened?
zilmosantos
Post by zilmosantos » Thu Aug 11, 2022 2:44 am
Maybe QCAD could be able to save on the dxf the "last state" of the drawing. If I saved on the Model and closed, it would open on Model... and if my last save was on the Layout"n", it would open on Layout "n".
Post by Husky » Thu Aug 11, 2022 7:09 am
That is how it works right now plus a feature since Version 3.25.0 to open files that were open when quitting the last session.
good point but currently not possible. You may consider to file a feature request below:
zilmosantos
Post by zilmosantos » Fri Aug 12, 2022 1:15 pm
https://www.qcad.org/bugtracker/index.p ... sk_id=2387
Thank you Husky!
