(Solved) Stamps - Date Time File Name
seasdes
Senior Member
Post by seasdes » Sat Jul 09, 2022 2:30 am
Hi All
I thought that I saw a how to install Date Time & Filename stamps in QCAD. However, I cannot find it. Is there a way to do this?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Stamps - Date Time File Name
Post by Husky » Sat Jul 09, 2022 2:42 am
No.
seasdes
Senior Member
Post by seasdes » Sat Jul 09, 2022 4:22 am
Thanks Husky
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Post by CVH » Sat Jul 09, 2022 7:50 am
Clive has entered a feature request back in sept. 2012:
https://www.ribbonsoft.com/bugtracker/i ... ask_id=687
Relevant topic:
https://www.qcad.org/rsforum/viewtopic.php?p=6967
It would be not that hard with a script but the question is what and where.
A simple text field that is created/updated with a button would be easy.
An attribute should be possible.
'On save' would require the use of a transaction listener excluding 'Autosave'.
I am not fond with the kind that is automatically updated on opening e.g. the MS Word/Excel date and time field. :wink:
