Contour lines
Richard L.
Contour lines
Post by Richard L. » Fri Jun 10, 2022 6:48 pm
If possible, how can I automatically trace contour lines from points (x;Y;Z;DESCRIPTION) I have imported from a file ?
If not possible now, will it be in a near-future version?
Windows 10 64 bit
QCAD Pro version 3.26.4.0
Re: Contour lines
Post by andrew » Fri Jun 10, 2022 7:15 pm
Yes, this should be possible:
https://www.qcad.org/en/tutorial-reusin ... -positions
For step 3, use
Draw > Line > Line from 2 Points
If you can't solve it, please do attach your file (see also forum rules above).
Re: Contour lines
Post by CVH » Sat Jun 11, 2022 5:20 am
Richard,
The question remains what you want to do with the Z value and the description.
QCAD is 2D and only has a minimum support for Z values.
What serves the description for of each line piece in a contour?
That could be stored in a custom property.
Then again, the description is rather linked to the position then to the lines between them.
