Viewport Scaling in Architectural Imperial Dwgs
Circle
Post by Circle » Mon Apr 18, 2022 6:03 pm
Mac OS 12.3.1
QCAD version 3.27.1.0 (3.27.1)
I am trying to create a 1/4" = 1'-0" scale Viewport.
In Layout Paper before selecting Draw>Viewport I can choose from Scale Window 1/4" = 1'-0
But this according to manual is the incorrect process.
I set page scale to 1"=1".
Then I select the Viewport>Draw tool and look to select scale but only metric scales available.
I choose 1/100
After placing viewport in Layout I then select the viewport and change the scale to 0.0208
For 1/2" = 1'-0" I use a scale 0.0417
is this the correct method or am I going to end up in hot water?
Mac: Big Sur version 11.4
QCAD Pro
Re: Viewport Scaling in Architectural Imperial Dwgs
Post by Husky » Mon Apr 18, 2022 7:22 pm
Yes that approach would be correct ...
for 1/4" = 1'-0"
you can use 0.020833333 or 1/48
for 1/2" = 1'-0"
you can use 0.041666667 or 1/24
Note: The combo box for the scale value will accept a written in 1/24 or 1/48 during the inserting process - no need to change that later in the Property Editor.
Just to give you a head up - most likely the next QCAD update will offer imperial scales in the combo box for Viewports too ...
https://www.qcad.org/en/changelog
Circle
Post by Circle » Mon Apr 18, 2022 8:27 pm
Thanks Husky for your incredibly fast response.
Just used your suggestion to type in 1/48. Makes life a lot easier :)
Looking forward to the update.
QCAD Pro
