Draw Line Perpendicular to another line?
HappyShat
Post by HappyShat » Sat Feb 19, 2022 1:42 am
Let's say I have a line and I want to draw a second line perpendicular to the first line. Where the end of the second line touches some point on the first line.
Is there a single command way of doing this?
I'm using Windows 10 Pro. and QCAD version 3.23.0.0.(3.23.0)
Re: Draw Line Perpendicular to another line?
Post by Husky » Sat Feb 19, 2022 1:49 am
Will the Orthogonal Tool do the trick for you ...? :wink:
https://www.qcad.org/doc/qcad/latest/re ... al_en.html
HappyShat
Post by HappyShat » Sat Feb 19, 2022 5:26 pm
Yes, the orthogonal tool works! Thanks! I had tried using the orthogonal tool earlier - but confused the intersection tool with the orthogonal tool - the icons look similar.
Post by CVH » Sun Oct 16, 2022 8:15 pm
Agreed, a little arc should do the trick :wink:
