Windows 10 home
QCad professional Trial Version
I am trying to print my first test drawing. I'm in PaperSpace with an A size page with one viewport. Borders, title block etc. are also on the page. These were from the template that Husky provided. All of the geometry in the viewport print perfect. But the title block and borders don't print. When I export the page to a pdf file the title block and borders are shown but kind of faded. I'm hoping that this is because I'm still on the trial and not something that I am doing wrong. Any ideas?
Rich
Title Block and frames not printing (solved)
Re: Title Block and frames not printing
I'm sorry I have to break the fact to you but that isn't because you are using the Trial.
I assume both blocks are on the same layer. Check the color of that layer - is it black? Next possibility could be the line weight - is it 0?
Re: Title Block and frames not printing (solved)
Thanks for the fast reply. The line weight was very thin and the color was light grey. Made the line wider and changed the color to black.
Problem Solved
Rich
(note: I'll have another question about the title block attributes but will start a new topic)
Problem Solved
Rich
