100% cpu usage
nicokid
100% cpu usage
Post by nicokid » Wed Jan 26, 2022 3:10 pm
I have been using qcad for some time on linux ubunti 18.04. Today I have to open a large 96Mb dwg file.
Unfortunately the program is very slow and one of the 12 CPUs is 100%
I have read that since release 3.24.0 qcad uses multithreading on multiple cpu. But using the "top" command I always see only one cpu used by qcad
Is there any way to solve this problem? Or is it possible to convert the dwg file to a less difficult format for qcad?
Thanks.
Re: 100% cpu usage
Post by Husky » Wed Jan 26, 2022 8:35 pm
Unfortunately QCAD is not build to handle 96Mb files. There is not a fix threshold but files around 10 - 20 Mb are already a big deal for QCAD ... :wink:
I haven't seen the file but most likely - no. I assume there are a lot of hatches and maybe overkill blocks in the drawing. To make it more workable you can try to transfer those "things" to a dedicated layer and turn it to invisible. Other possibility would be to divide the drawing into e.g. 10 drawings ... I don't know how practical that would be ...
Re: 100% cpu usage
Post by CVH » Thu Jan 27, 2022 7:59 am
Husky,
A file does not grow only because of many hatches.
A hatch is just an entity, defined with a boundary as a polyline and a named pattern.
The pattern itself is also included. These are usually small.
Together they don't take up much space in a dwg file.
Problematic hatch patterns or a large origin offset or the scale of things may slow down rendering under QCAD ... After a file is loaded.
The use of blocks may even decrease size.
But indeed, a 96 MB (binary) dwg file will contain a vast amount of entities.
Hidden or not.
A 100Mb dxf file is usually not a problem.
Finally 'Auto save' can be problematic as that uses the dxf format.
nicokid
Re: 100% cpu usage
Post by nicokid » Fri Jan 28, 2022 10:26 pm
Ok, thanks for the answer.
The dxf files are text files and unfortunately they are too big :cry:
Unfortunately this is a factory layout consisting of several machines. It was built by taking the technical drawings of the machines and putting them together.
None of the designers are concerned with simplifying and rationalizing the layouts. Always the same problem with everyone. :evil:
Nicola.
Re: 100% cpu usage
Post by CVH » Sat Jan 29, 2022 3:56 am
Nicola,
Agreed ... The exact rendering of every 3mm nut won't make any sense on a factory layout :lol:
Only CAD has evolved to a level that this can be.
One could render every single fiber in a Airbus A380plus its carpets.
And that comes at a price. :wink:
