can i change color outside print area in paper space?
stansu
Post by stansu » Wed Aug 04, 2021 3:25 am
can i change color grey to black?
windows 7
version 3.26.4.0
Re: can i change color outside print area in paper space?
Post by Husky » Wed Aug 04, 2021 8:26 am
No. You can change the print area color but not the grey area. To change the paper background go to Edit > Drawing Preferences > Printing > Colors > Background Color.
stansu
Post by stansu » Thu Aug 05, 2021 1:33 am
thanks for reply. should i move this post to suggestion?
Post by Husky » Thu Aug 05, 2021 2:28 am
Sure - you can do that. But you would get a better chance if you fill a feature request below:
https://www.qcad.org/bugtracker
Note: The QCAD Forum login will not work there - you need to register again to get access.
