If I have multiple circles where at least one is embedded within another, how can I dimension these without having the dimensions overlap (see the image and dxf file)? Radial dimensions have the same problem. QCAD should allow the dimensions to be placed outside the circles but I can't see any way to do this. The only work-around I see is to use a leader.
QCAD 3.25.2
Windows 7 Pro
Thanks,
Don C.
How to dimension multiple embedded circles?
- Circles, dimensioned (1a).dxf
- (101 KiB) Downloaded 256 times
- petevick
- Premier Member
Re: How to dimension multiple embedded circles?
you can select a dimension then select the reference point for the dimension text and drag the text to where you want it
Pete Vickerstaff
However, this becomes a little "messy" and potentially somewhat confusing if the dimension line doesn't extend when the dimension text is moved. See --
- petevick
- Premier Member
Yes, it does indeed, you could add your own line, but again, gets even messier.
You could ask for this feature to be included here -> viewforum.php?f=31 or even at the bug tracker here -> https://www.ribbonsoft.com/bugtracker/
Pete Vickerstaff
