Activate Distance by keyboard shortcut
That’ because conflicting letter D.
I've created bug https://www.ribbonsoft.com/bugtracker/i ... sk_id=2188
but may be there's other solution (may be unknown to me shortcut)?
Re: Activate Distance by keyboard shortcut
Actually - the default shortcut to focus on the option bar is Ctrl+Space or ⌃Space depending on the OS ...jooogger wrote: ↑Sun Feb 14, 2021 3:17 pmWhen user activated LIne → Parralel (LP), there’s two input fields - Distance and Number. Keyboard shortcut Alt-N activated Number input field very well, but shortcut Alt-D activate menu Draw instead. So user forced to point Distance input field by mouse.
https://qcad.org/archives/shortcuts/shortcuts_en.pdf
Husky wrote: ↑Sun Feb 14, 2021 6:35 pmActually - the default shortcut to focus on the option bar is Ctrl+Space or ⌃Space depending on the OS ...
Fine! It's good to add tooltip "Ctrl-Space" to first input field.
