[solved] Command Line Tools
dfriasb
Senior Member
Post by dfriasb » Mon Jan 25, 2021 9:07 pm
Hello all,
I'm trying to use dwg2dwg command line tool with qcad-3.24.3-pro-linux-x86_64. I'm getting "No such file or directory" when trying to execute it in shell. I was looking in dwg2dwg file and I found it is asking for this file:
scripts/Pro/Tools/Dwg2Pdf/Dwg2Pdf.js
I have no Pro folder inside "scripts".
Maybe I'm losing something... :( Can anyone help me? Thanks a lot.
David
Re: Command Line Tools
Post by andrew » Mon Jan 25, 2021 9:51 pm
Scripts are compiled into plugins (virtual file system). This should not be the problem.
How do you call dwg2dwg?
The correct order of arguments is for example:
./dwg2dwg -o output.dwg input.dxf
See also:
https://qcad.org/en/products/qcad-comma ... ls#dwg2dwg
dfriasb
Senior Member
Post by dfriasb » Tue Jan 26, 2021 9:58 pm
Thanks a lot!
