[Solved ]How to adjust length of extension line on dimensions
Eugor
Post by Eugor » Sat Jan 09, 2021 11:45 pm
QCAD Pro 3.22.0.0 Linux Mint 20 Xfce
How do I adjust the length and position of dimension extension lines ? I would like to leave a space of say half what is shown on the extension lines. I have drawn a line thru where I would like the lines shown. How do I make this adjustment in the settings ?
Eutopia1.2dxf.dxf
(102.34 KiB) Downloaded 347 times
Re: How to adjust length of extension line on dimensions
Post by Husky » Sun Jan 10, 2021 1:14 am
Try a different value (22 or so) for Extension line offset ...
Eugor
Post by Eugor » Sun Jan 10, 2021 1:25 am
Damn Husky, You are the bomb. Thank you kindly
