Hello all,
It's great that you can see different lineweights in model space when you have Screen-based linetypes activated. I would like to know it it is possible to change its behavior; I would like to see thicker lines from 0.25mm or 0.35mm, instead of 0.50mm like it is right now.
I is possible anyway? Thanks a lot!
David
Lineweights in model space
Re: Lineweights in model space
No, this cannot currently be changed.
