[solved] ... edit the border of a hatch region?
- Junior Member
How do I ... edit the border of a hatch region? I have some grips from when I made the hatch region but I can't find a way to add or remove grips.
Last edited by Duncan Lithgow on Tue Oct 20, 2020 8:59 pm, edited 1 time in total.
Re: ... edit the border of a hatch region?
It's possible to a certain degree (stretching, scaling, moving), but you'd typically keep the hatch boundary on a separate layer and edit that, then recreate the hatch.
If you don't have the hatch boundary anymore, you can change the hatch to a solid (change property "Solid" to true), then explode it (Modify > Explode). This gives you the boundary as lines, arcs, etc.
- Junior Member
Okay, that works. Maybe that workflow could be described in the manual. Thanks
