Working with viewport
Roberto Vid
Post by Roberto Vid » Sun Oct 18, 2020 5:39 pm
Where can I have a tutorial on viewport, with an example, and how to insert sheets A0, A1, A2, A3 and A4 in the viewport scale.
Thank you,
greetings
Re: Working with viewport
Post by Husky » Sun Oct 18, 2020 11:27 pm
CVH gave you already a hint in an other topic ...
viewtopic.php?f=47&t=7644&p=29754#p29754
... and this is an ANSI A example from me how it could work:
ANSI A example.dxf
(187.57 KiB) Downloaded 344 times
Maybe useful as basic for your case.
