Greetings all, I have some site drawings I am doing on top of bitmap satellite images.
I fade the bitmap so the drawing stands out.
However when I export to PDF the fade is lost.
And advice?
I can just fade the images before I import them to qcad.
Is it possible to Export bitmap fade?
Comments based on Version: 3.26.2 unless otherwise noted.
Re: Is it possible to Export bitmap fade?
Nope - it isn't. Do you use a third party pdf creator?
Hi Husky thanks for your reply.
I am using the pdf export button on qcad 3.23
So your saying its not possible to export the fade?
I made a simple test drawing green.dxf using the canvas_green.png as a test bitmap.
I exported it as green50.pdf setting the bitmap to a 50% fade.
and exported as green.pdf with no fade.
They both look the same.
It appears bitmaps are stored separately from the dxf format.
I am a big fan of imagemagick and can use the command
to set a 50% fade etc.
- green50.pdf
- (12.81 KiB) Downloaded 289 times
- green.pdf
- (12.81 KiB) Downloaded 276 times
- green.dxf
- (165.24 KiB) Downloaded 297 times
- canvas_green.png (351 Bytes) Viewed 2657 times
No, I said it is no problem to fade an image in QCAD Pro and export it then as a pdf.
