Add Javascrpt for text along curve
bta plasma
Post by bta plasma » Thu Sep 03, 2020 4:20 pm
I am trying to add this permanently to Qcad running in Linux. I cannot seem to get it to work. Sorry if its a newbie question. Can someone help?
 * \defgroup ecma_draw_text TextAlong Drawing Tool
 * \ingroup ecma_draw
 * \brief This module contains the ECMAScript implementation of the text along an entity
 * drawing tool.
include("scripts/Draw/Draw.js");
include("scripts/WidgetFactory.js");
include("scripts/Draw/Text/TextDialog/TextDialog.js");
 * \class TextAlong
 * \brief Insert text along an entity.
 * \ingroup ecma_misc_draw
function TextAlong(guiAction, mode) {
    if (isNull(mode)) {
        mode = TextDialog.Mode.Text;
    Draw.call(this, guiAction);
    this.textData = undefined;
    this.mode = mode;
    this.entity = undefined;
    this.text = undefined;
    this.height = 1.0;
    this.spacing = 0.0;
    this.pos = undefined;
    this.ccw = false;
    this.fit = false;
    this.CharWidths = [];
    this.totalCharWidth = 0.0;
    this.setUiOptions("TextAlong.ui");
TextAlong.prototype = new Draw();
TextAlong.State = {
    ChoosingEntity : 0,
    SettingPosition : 1
TextAlong.prototype.beginEvent = function() {
    Draw.prototype.beginEvent.call(this);
    var dialog = new TextDialog(this.mode);
    this.textData = dialog.show();
    if (isNull(this.textData)) {
        this.terminate();
        return;
    var optionsToolBar = EAction.getOptionsToolBar();
    var contentsEdit = optionsToolBar.findChild("Contents");
    WidgetFactory.initLineEdit(contentsEdit, false);
    contentsEdit.text = this.textData.getEscapedText();
    var heightEdit = optionsToolBar.findChild("Height");
    var ht = heightEdit.getValue();
    this.textData.setTextHeight(ht);
    // generate list of char widths
    this.getCharWidths();
    this.setState(TextAlong.State.ChoosingEntity);
TextAlong.prototype.setState = function(state) {
    Draw.prototype.setState.call(this, state);
    var appWin = RMainWindowQt.getMainWindow();
    this.setCrosshairCursor();
    switch (this.state) {
    case TextAlong.State.ChoosingEntity :
        this.getDocumentInterface().setClickMode(RAction.PickEntity);
        this.setCommandPrompt(qsTr("Select Entity"));
        this.setLeftMouseTip(qsTr("Select Entity"));
        this.setRightMouseTip(EAction.trCancel);
        EAction.showSnapTools();
        break;
    case TextAlong.State.SettingPosition :
        this.getDocumentInterface().setClickMode(RAction.PickCoordinate);
        this.setCommandPrompt(qsTr("Position"));
        this.setLeftMouseTip(qsTr("Position"));
        break;
TextAlong.prototype.pickEntity = function(event, preview) {
    var doc = this.getDocument();
    var entityId = event.getEntityId();
    var entity = doc.queryEntity(entityId);
    this.pos = event.getModelPosition();
    if (isNull(entity)) {
        return;
    } else {
        if (!preview) {
            var type = entity.getType();
            if (type !== RS.EntityLine && type !== RS.EntityArc && type !== RS.EntityCircle) {
                EAction.handleUserWarning(qsTr("Selected entity is not a Line, Arc or Circle!"));
                return;
            this.entity = entity;
            this.setState(TextAlong.State.SettingPosition);
TextAlong.prototype.pickCoordinate = function(event, preview) {
    if (!preview) {
        di.setRelativeZero(this.pos);
    this.textData.setAlignmentPoint(this.pos);
    this.text = new RTextEntity(this.getDocument(), this.textData);
    var op = this.getOperation(preview);
    if (preview) {
        di.previewOperation(op);
    else {
        if (!isNull(op)) {
            di.applyOperation(op);
TextAlong.prototype.getOperation = function(preview) {
    var type;
    if (!isNull(this.entity)) {
        type = this.entity.getType();
    } else {
        return undefined;
    var op = undefined;
    switch(type) {
    case RS.EntityLine :
        op = this.alongLine();
        break;
    case RS.EntityArc :
        // 'this.entity' is a pointer to the arc, so get the actual arc object
        var arc = this.entity.getData().getArc();
        op = this.alongArc(arc);
        break;
    case RS.EntityCircle :
        // create a circular arc and use 'alongArc'.
        // when using 'fit', add one or more spaces to the start or end of the text
        var arc = new RArc(this.entity.getCenter(), this.entity.getRadius(), 0.0, 0.0);
        break;
    default :
        break;
    return op;
TextAlong.prototype.getCharWidths = function() {
    var txt = this.text.getPlainText();
    var num = txt.length;
    for (var i = 0; i < num; i++) {
        var char = txt[i];
        // A space character is returned as zero width
        if (char === " ") {
            char = "-";
        var td = this.getTextData(char);
        var wid = td.getWidth();
        this.CharWidths.push(wid + this.spacing);
        this.totalCharWidth += wid + this.spacing;
TextAlong.prototype.getTextData = function(txt) {
    var td = new RTextData();
    if (this.pos !== undefined) {
        td.setAlignmentPoint(this.pos);
    td.setVAlign(this.textData.getVAlign());
    td.setHAlign(this.textData.getHAlign());
    td.setText(txt);
    td.setTextHeight(this.textData.getTextHeight());
    td.setTextWidth(this.textData.getTextWidth());
    td.setFontName(this.textData.getFontName());
    td.setAngle(this.textData.getAngle());
    td.setBold(this.textData.isBold());
    td.setItalic(this.textData.isItalic());
    td.setLineSpacingFactor(this.textData.getLineSpacingFactor());
    return td;
TextAlong.prototype.slotContentsChanged = function(value) {
        return;
    this.textData.setText(value);
    // change list of char widths
TextAlong.prototype.slotHeightChanged = function(value) {
        return;
    this.height = value;
    this.textData.setTextHeight(this.height);
TextAlong.prototype.slotSpacingChanged = function(value) {
    this.spacing = value;
TextAlong.prototype.slotDirectionChanged = function(button) {
    if (!isQObject(button) || button.checked !== true) {
        return;
    if (button.objectName === "Clockwise") {
        this.ccw = false;
    else {
        this.ccw = true;
TextAlong.prototype.slotFitChanged = function(value) {
    this.fit = value;
TextAlong.prototype.alongLine = function() {
    var ang, len, op, h, v;
    ang = this.entity.getAngle();
    len = this.entity.getLength();
    if (!isNull(this.textData)) {
        if (this.ccw) {
            this.textData.setAngle(ang + Math.PI);
        } else {
            this.textData.setAngle(ang);
    op = new RAddObjectsOperation();
    if (this.fit) {
        var firstCharWidth = this.CharWidths[0];
        var lastCharWidth = this.CharWidths[num - 1];
        var dist = (len - firstCharWidth) / (num - 1);
        // now position 'this.pos'
        v = new RVector();
        h = this.textData.getHAlign();
        if (h === RS.HAlignRight) {
            v.setPolar(len, this.textData.getAngle() + Math.PI);
            this.pos = this.pos.operator_add(v);
        } else if (h === RS.HAlignCenter) {
            v.setPolar(len / 2.0, this.textData.getAngle() + Math.PI);
            var td = this.getTextData(txt[i]);
            var te = new RTextEntity(this.getDocument(), td);
            te.setSimple(true);     // This is required so 'base' and 'bottom' points are correct
            te.setVAlign(this.textData.getVAlign());
            te.setHAlign(RS.HAlignCenter);
            v.setPolar((dist * i) + (firstCharWidth / 2.0), te.getAngle());
            var pt = this.pos.operator_add(v);
            te.setAlignmentPoint(pt);
            op.addObject(te);
    } else {
        op.addObject(this.text);
    return op;
TextAlong.prototype.alongArc = function(arc) {
    var ang, op;
    // Fix bug: Fit option doesn't work on reversed arcs
    if (arc.isReversed()) {
        arc.reverse();
    // use distance from 'this.pos' to centre point of arc, as radius
    arc.setRadius(arc.center.getDistanceTo(this.pos));
    var pt = this.pos;
    ang = arc.center.getAngleTo(this.pos);
    var arcrad = arc.getRadius();
    // calculate spacing for 'Fit' option
    if (this.fit) {
        // subtract half the width of first character and last character
        var firstcharAngle = ((this.CharWidths[0]) / arcrad) / 2.0;
        var lastcharAngle = ((this.CharWidths[num - 1]) / arcrad) / 2.0;
        var fitAngle = (arc.getSweep() - firstcharAngle - lastcharAngle) / (num - 1);
    var td = this.getTextData(txt[0]);
    var h = te.getHAlign();
    //var v = te.getVAlign();
    // set rotation angle for first character
    var rotateAngle, sweep;
    var width = this.totalCharWidth;
    if (this.fit) {
        sweep = arc.getSweep();
    } else {
        sweep = width / arcrad;
    if (h === RS.HAlignLeft) {
        rotateAngle = 0.0;
        rotateAngle = sweep / 2.0;
    } else {
        rotateAngle = sweep;
    // get angle for half the first characters width
    // and subtract from rotateAngle
    var halfAngle = ((this.CharWidths[0]) / arcrad) / 2.0;
    rotateAngle -= halfAngle;
    if (this.ccw) {
        rotateAngle = -rotateAngle;
        h = te.getHAlign();
        //v = te.getVAlign();
        if (this.ccw) {
            te.setAngle(ang + (Math.PI / 2.0));
        } else {
            te.setAngle(ang - (Math.PI / 2.0));
        // draw each character at 'this.pos', and rotate to match alignment point
        te.rotate(rotateAngle, arc.center);
        op.addObject(te);
        // adjust point and angle for next character
        // function 'getCharWidths' handles spacing
        var currentcharAngle = (this.CharWidths[i]) / arcrad;
        var nextcharAngle = (this.CharWidths[i + 1]) / arcrad;
        var charAngle = (currentcharAngle / 2.0) + (nextcharAngle / 2.0);
        if (this.ccw) {
            if (this.fit) {
                rotateAngle = rotateAngle + fitAngle;
            } else {
                rotateAngle = rotateAngle + charAngle;
        } else {
            if (this.fit) {
                rotateAngle = rotateAngle - fitAngle;
            } else {
                rotateAngle = rotateAngle - charAngle;
    return op;
bta plasma
Re: Add Javascrpt for text along curve
Post by bta plasma » Thu Sep 03, 2020 4:28 pm
Can someone translate this to python for me? I understand it needs to be translated. It doesnt seem to work in windows either. I dont know if I have an error in there
Post by CVH » Thu Sep 03, 2020 4:41 pm
Don't understand 'translate', don't know why you need phyton.
Its a script. An included script.
As PRO posting in the PRO section ... type TG :roll:
And pls set the code in a code window </> :wink:
bta plasma
Post by bta plasma » Thu Sep 03, 2020 4:47 pm
Thank you for your patience. The script does not work. Is there a way to do text along a curve without aligning each letter? I dont know what you mean by typing TG. I know this might seem like entry level stuff to you but it is very new to me.
bta plasma
Post by bta plasma » Thu Sep 03, 2020 4:49 pm
OK TG in the command prompt. Thanks!
bta plasma
Post by bta plasma » Thu Sep 03, 2020 5:37 pm
TG command is not listed in the manuals, nor in the submenus, nor is there a reference that can be googled. It has been quite a mystery.
petevick
Post by petevick » Thu Sep 03, 2020 6:38 pm
TG is the shortcut for the Text Along Entity command, you can also type textalong in the command line. This may be a Pro command, are you using Pro or Community edition ?
Pete Vickerstaff
Post by CVH » Thu Sep 03, 2020 8:01 pm
Shortcuts are listed here:
https://qcad.org/archives/shortcuts/shortcuts_en.pdf
Tried the search function on this Forum?
Try 'text along'
2 pages
Start on the bottom of page 2 (Evident :roll: )
Go up to Sun May 28, 2017
https://www.qcad.org/rsforum/viewtopic. ... ong#p17972
Start there.
Finally, it's not so ok that you left the copyright notice out.
Then again, in this case it was on the QCAD forum ... :wink:
Nowadays the script in included.
Here is the original source:
https://github.com/qcad/qcad/blob/maste ... xtAlong.js
