elastic stretching or bending
rui_fartaria
Post by rui_fartaria » Wed Jul 29, 2020 7:58 pm
I could not find anything in the forum or manual about this.
Are there any transforms implemented that allow to stretch or bend a polyline according to an elastic function across the line.
What I mean is, I want to to be able to pick the end of the line and drag it so that the full polyline is transformed with decreasing intensity as distance increases (along the line) from the end of the line.
Also, this would be valid for any point of the polyline.
Thank you in advance for your attention.
Re: elastic stretching or bending
Post by Husky » Wed Jul 29, 2020 9:04 pm
Hi
You can't "bend" a polyline but you can "bend" a spline ...
You can design a polyline with a start width of ... let say zero and an end width of 25. If you then drag the end it will behave like a rubber line ... :wink:
rui_fartaria
Post by rui_fartaria » Wed Jul 29, 2020 9:50 pm
HI,
I was trying to experiment with the behaviour you explained (progressive width) but could not see it. Only the last segment moved. Not the whole polyline.
I will have to implement this myself. If I succeed i'll try to make it available as a script/macro.
Thanks.
Post by CVH » Thu Jul 30, 2020 7:10 am
Very interesting,
Keep us posted. :wink:
rui_fartaria
Post by rui_fartaria » Wed Aug 05, 2020 2:08 pm
What I have so far....
paste this into the ecmascript console or run it as a script.
it will:
1. create a horizontal polyline from x=0 to x=100 with 100 vertices
2. will "bend" left tip with offset (20,20)
2. will "bend" rigth tip with offset (-20,20)
This bending model uses exponential decay. I've been experimenting with others but this is the best I found for my objectives. If anyone can tell about any literature on this (plastic bending mathematical models) I would very much appreciate it.
Final result should be:
https://pasteboard.co/JkXBUm8.png
The script:
function makeExponentialDecay(factor) {
    return function (length) {
        var r = Math.exp(-factor*length);
        return r < 0.001 ? 0.0 : r;
function makeExponentialDecayFullLine(lineLength) {
    var factor = 3 * Math.log(10) / lineLength;  // weight = 1.0E-3 at farthest point
    return makeExponentialDecay(factor);
//  * @param {RPolyLineEntity} polyLineEntity
//  * @param {number} ivertex
//  * @param {function (length)} weightsFunc
//  * @param {RVector} offset
function polylinePlasticBending(polyLineEntity, ivertex, weightsFunc, offset) {
    var nvertex = polyLineEntity.countVertices();
    if (ivertex !== 0 && ivertex !== nvertex-1 ) {
        throw "Not implemented!";
    var vertices = polyLineEntity.getData().getVertices();
    var lengths = [];
    var i;
    for (i=0; i<nvertex-1; i++) {
        lengths.push(polyLineEntity.getSegmentAt(i).getLength());
    for (i=nvertex-1; i>=0; i--) {
        polyLineEntity.removeLastVertex();
    if (ivertex === 0) {
        // first vertex
        var weight = weightsFunc(0.0);
        var newVertex = vertices[0].operator_add(offset.operator_multiply(weight));
        polyLineEntity.appendVertex(newVertex);
        var d0 = 0.0;
        for (i=1; i<nvertex; i++) {
            d0 += lengths[i-1];
            var weight = weightsFunc(d0);
            var newVertex = vertices[i].operator_add(offset.operator_multiply(weight));
    } else if (ivertex === nvertex-1) {
        var d0 = 0.0;
        for (i=0; i<nvertex-1; i++) d0 += lengths[i];
        // first vertex
            d0 -= lengths[i-1];
    } else {
    var op = new RModifyObjectOperation(polyLineEntity);
    var transaction = this.getDocumentInterface().applyOperation(op);
    return transaction;
//  *** begin operations
var doc = this.getDocument();
var vertices = [];
for (i=0;i<100;i++) vertices.push([i*1,0,0]);
addPolyline(vertices, false);
// find out ID of polyline, that was added to the document:
var ids = doc.queryAllEntities();
for (var i=0; i<ids.length; ++i) {
    var id = ids[i];
    var entity = doc.queryEntity(id);
    if (isPolylineEntity(entity)) {
        plp = entity;
        break;
var transaction = polylinePlasticBending(plp, 0, makeExponentialDecayFullLine(plp.getLength()), new RVector(20,20,0));
var ids = transaction.getAffectedObjects();
    var id = ids[i];
        plp = entity;
        break;
var r = polylinePlasticBending(plp, plp.countVertices()-1, makeExponentialDecayFullLine(plp.getLength()), new RVector(-20,20,0));
