convert svg to dxf command line (server)
- Registered Member
Hello, I'm using Qcad server (paid version), I'd like to know if it's possible to convert svg files to dxf via command line
Re: convert svg to dxf command line (server)
Yes, all QCAD Professional licenses come with a simple command line utility "svg2dwg" which can convert SVG to DXF or DWG:
This is very basic and results depend on the type of input file used.
svg2dwg -o output.dxf input.svg
