How did I set an offset? (dragging object)
turtle
Post by turtle » Mon Jun 22, 2020 3:15 am
Once in a while,
I am working in a drawing and select an object, and the 'snap free' option and attempt to drag it to another position.
However the object is offset a distance away from where my curser is moving.
I try 'escape' and a few other tings to reset it but no luck.
Reloading the CAD file seemed to fix it, and now I cant reproduce the problem to see how I triggered it.
Does any one have an idea of what I am doing to cause that?
Thanks in advance
Comments based on Version: 3.23 unless otherwise noted.
Re: How did I set an offset? (dragging object)
Post by andrew » Mon Jun 22, 2020 6:56 am
Perhaps you accidentally enabled a snap restriction:
https://qcad.org/doc/qcad/latest/refere ... Orthogonal
If you cannot solve it, please provide more details, screenshots, what direction is the offset in, etc.
turtle
Post by turtle » Thu Jun 25, 2020 7:39 pm
Hi I did it again.
I have no idea what causes this, and I'd love to know.
I click on the text 'Move this' you can see its selected in its original place with its blue square.
I am dragging to move it down near the bottom of the page you can see the cross hairs,
and it's moving relative to zero.
When I checked the snap it said restriction off.
I dont know how to take a screen shot that shows the cursor so here is this foggy photo:
(Reloading the file the file resets everything and I can drag things like normal)
what_did-i_do_again.dxf
(105.38 KiB) Downloaded 21 times
Post by Husky » Thu Jun 25, 2020 8:23 pm
The "Alt key" on your Keyboard isn't pressed, correct? Or maybe an other restriction tool ...?
Post by CVH » Fri Jun 26, 2020 5:10 am
The most interesting sections off the screen are out of the picture...
In Win shift+PrtScrn ('PrintSrcreen') and paste it in a picture application.
There are a multitude of screen-grabbers too.
That's probably why we can't reproduce this with your file.
Reloading or Rebooting Qcad?
Because it seems to me that this has to be an application issue.
There isn't a layout defined ... are you editing in PrintPreview?
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
