SVG-import doesn't respect stroke-width
Krischu
Post by Krischu » Sun Mar 22, 2020 12:49 pm
I have drawn a rectangle and gave it the linewidth 0.
This seems to reflect in the source code (stroke-width:0).
But when importing the SVG later on, the rect is drawn with a line-width according to the layer. Is this intended?
If I give the layer the associated line_weight 0 it doesn't show in the SVG export.
<?xml version="1.0" encoding="UTF-8"?>
<!-- 2020-03-22 12:27:26 Generated by QCAD 3.24.3 SVG Exporter -->
<svg width="70mm" height="10mm" viewBox="10 -20 70 10" version="1.1" xmlns="http://www.w3.org/2000/svg" style="stroke-linecap:round;stroke-linejoin:round;fill:none">
    <g transform="scale(1,-1)">
        <!-- Line -->
        <path d="M10,10 L80,10 " style="stroke:#000000;stroke-width:0;"/>
        <!-- Line -->
        <path d="M80,10 L80,20 " style="stroke:#000000;stroke-width:0;"/>
        <!-- Line -->
        <path d="M80,20 L10,20 " style="stroke:#000000;stroke-width:0;"/>
        <!-- Line -->
        <path d="M10,20 L10,10 " style="stroke:#000000;stroke-width:0;"/>
    </g>
</svg>
rect_lw_0.svg
(704 Bytes) Downloaded 359 times
Christoph
Re: SVG-import doesn't respect stroke-width
Post by CVH » Sun Mar 22, 2020 1:03 pm
A: What SVG export method?
One can preserve the overall look or the geometry.
B: Line_weight 0 = no weight in SVG and can not be shown.
CVH.
Krischu
Post by Krischu » Sun Mar 22, 2020 5:41 pm
CVH,
thanks. I used both Advanced SVG export
What do you mean by
"B: Line_weight 0 = no weight in SVG and can not be shown." ?
Christoph
Post by CVH » Sun Mar 22, 2020 7:07 pm
What it says: A zero weight in SVG is a line with no visible size.
Qcad among other CAD's display a minimum.
Post by andrew » Sun Mar 22, 2020 10:36 pm
This is an SVG import limitation. SVG import imports to the current layer (as SVG doesn't have layers) and sets lineweight and linetype to "By Layer". Only the color attribute is currently imported.
I wouldn't recommend to export / import SVG when working on a file. Always use DXF to preserve all information in the file.
Krischu
Post by Krischu » Mon Mar 23, 2020 8:36 am
Yes, sure. DXF is the way to exchange back and forth. Nonetheless a bit more completeness in SVG import wouldn't be bad. For example, a fill (hatch) isn't imported either.
<!-- 2020-03-23 07:36:57 Generated by QCAD 3.24.3 SVG Exporter -->
        <!-- Line -->
        <path d="M10,10 L80,10 " style="stroke:#ff0000;stroke-width:0;"/>
        <!-- Line -->
        <path d="M80,10 L80,20 " style="stroke:#ff0000;stroke-width:0;"/>
        <!-- Line -->
        <path d="M80,20 L10,20 " style="stroke:#ff0000;stroke-width:0;"/>
        <!-- Line -->
        <path d="M10,20 L10,10 " style="stroke:#ff0000;stroke-width:0;"/>
        <!-- Hatch -->
        <path d="M10,10 L80,10 L80,20 L10,20 Z" style="fill:#ff0000;fill-rule:evenodd;"/>
    </g>
</svg>
rect_lw0_red.svg
(817 Bytes) Downloaded 365 times
Christoph
Post by andrew » Mon Mar 23, 2020 8:43 am
Confirmed. SVG import is definitely only partial, mainly to import the geometry. We currently have no plans to improve SVG import. Note that SVG also has many features not available in DXF and vice versa. It's a presentation format, not a CAD format.
