Win 10, QCad 3.24
I was wondering how you put hidden lines on the drawings. 'Hidden lines- as for edges that cannot be seen from that view.'
Thanks,
Papajoe41
Hidden lines
Re: Hidden lines
It is common practice in CAD to use Layer with different Attributes for Linetype, Line weight etc. etc.
This tutorial explains the idea behind it:
https://qcad.org/en/tutorial-working-with-layers
A basic layer list could look like my one but you are free to change it to what ever works best for you.
To draw a hidden line you have to make the Hidden Layer active and draw the lines.
