Trim to Circle Center
When using the Trim Command is there a way to select circle center as the limiting entity? If not how is the best way to trim or extent a line to circle center? Thanks
Re: Trim to Circle Center
In neutral mode (no tool running), select the line and drag and drop the end point of the line to the circle center. To keep the line at the same angle, hold down the shift key.
