In the attached graphic, I want to construct an arc that passes through the intersection of the line and arc at point C and is tangent to the lines A and B. The line passing through point C is the bisector of lines A and B, so I know the center of the arc will lie on this line, but I can't seem to figure out how to construct this arc.
Can someone help me see what I'm missing as I'm reasonably certain there's a tool in QCAD that will help me with this.
Linux Mint 19.1
QCAD 3.23.0.0
Bill Lugg
Constructing an arc through a point tangent to two lines
- Opening.png (10.66 KiB) Viewed 3203 times
Re: Constructing an arc through a point tangent to two lines
Thanks. I found these tools shortly after I posted this an then soon discovered the bug you mentioned. I'll download the latest version and give it a spin.
Bill Lugg
Bill Lugg
