I am just getting started with QCAD Professional. At first everything was ok. Then rulers and grid disappeared. Despite much fiddling with "Drawing Preferences" and "Application Preferences", I am not able to get them back. Any help would be appreciated.
Windows 10, QCAD 3.24.2.0(3.24.2).
[solved] no rulers, no grid
Re: no rulers, no grid
Let's start with the rulers. They are activated below ...
Thank you for your prompt reply. However, "Show rulers" is and has been checked with no rulers.
I assume it is a clean installation what means there is no chance that different QCAD versions are mixed in the same directory. Correct?
If possible please attache a screenshot.
Have you tried to reset QCAD? https://qcad.org/en/tutorial-resetting- ... figuration
Thanks for how to reset. I am in business but will surely have more questions. Thanks again.
You're welcome.
