QCAD Community Edition
Terry Lawson
Post by Terry Lawson » Sat Nov 23, 2019 1:50 pm
How do I find and remove:
plugins\qcadcamscripts.dll and plugins\qcadnest.dll
These are the files that I have been requested to remove by clicking on "Remove in the Trial widget".
Regards
Terry Lawson
lphilpot
Senior Member
Re: QCAD Community Edition
Post by lphilpot » Sat Nov 23, 2019 4:40 pm
The plugins directory is under your QCAD installation directory. I'm on Linux these days, but on Windows if I recall correctly it should be either "C:\Program Files\qcad<version>" (64 bit) or "C:\Program Files (x86)\qcad<version>" (32 bit). Make sure QCAD isn't running and delete, move or rename those files using Windows Explorer. Restart QCAD and you're good.
Len
QCAD Pro
Post by Husky » Sat Nov 23, 2019 5:25 pm
Removing the QCAD Trial Add-Ons:
viewtopic.php?f=76&t=4668#p17085
