Display Radians in properties
ljbuller
Post by ljbuller » Sat Sep 14, 2019 3:22 pm
I have found the setting to display radians in dimensions. Is there a way to display radians in the properties widget?
Windows 10
QCAD 3.23
Re: Display Radians in properties
Post by Husky » Sat Sep 14, 2019 6:18 pm
It's displayed as "length":
ljbuller
Post by ljbuller » Sat Sep 14, 2019 8:34 pm
No, I don't think that is right.
The radian equivalent to 180 degrees = pi = 3.1415
The radian equivalent to 90 degrees = pi/2 = 1.5707
in your example the radian equivalent of 116.2696 deg = 2.0292 radians
arc length in measurement units = radius * sweep in radians = 13.8484 * 2.0292 = 28.01023. That is what is showing as length in your example.
In the attached file there are 2 arcs, each with a radius of .5"
If I select the 180 degree arc in my file, the length says 1.57, where the radial equivalent to 180 deg = 3.14
radians on arc properties.dxf
(189.39 KiB) Downloaded 441 times
Post by Husky » Sat Sep 14, 2019 9:29 pm
Yes, you're correct. Sorry for that :oops:
Post by CVH » Sun Sep 15, 2019 2:12 pm
Edit / Application Preferences / Dimension Settings for new drawings.
Edit / Drawing Preferences / Dimension Settings for actual drawing.
As it is remarked out in many scripts I've crossed,
I am not sure if it will ever display units in widgets
Never crossed a value with a unit.
There are ways with the Property Label to include anything you like.
text in front of the value<>this text behind the value.
<> represent the measured value.
eg. '<>mm' , '+/-<>'
I would look that up
ljbuller
Post by ljbuller » Sun Sep 15, 2019 4:27 pm
I have found and changed both drawing and application preference settings to indicate radians. this does not change how the angle is displayed in properties.
You mention scripts.
I am not up to speed on scripts but would like to be.
My first attempt on educating myself was to go to the reference manual.
contents: nothing for the misc menu
Index: look for scripts = nothing
search: one return on CAM legacy support, nothing on implementing scripts
Ah Ha, I see menu - misc - script tutorials
Click Menus and tool bars = nothing
click Persistent widgets = Enter position dialog.
Clearly I need some direction here where to look for newby support on scripts.
Also some direction where to go for information on the "There are ways with the Property Label to include anything you like." would be appreciated.
Post by CVH » Sun Sep 15, 2019 5:30 pm
Some direction for newby support on scripts
Me too. :wink:
A good start was to 'read' them through.
Although my knowledge of Qt and javascript is fairly nill.
As they are most certainly only present in compiled form, the individual master scripts can be found on Github.
Look for the Qcad project.
It is not necessary to put them under the Qcad scripts folder.
Script .js files in there will take priority over the compiled versions.
That is for including something extra in dimension labels...in your drawing.
I was misleaded by the pic in Husky's reply.
I now understand that you want units in the Property Editor.
Well, I know of no units displaying in the Property Editor.
So I looked it up for you with searching the forum to start.
https://qcad.org/rsforum/viewtopic.php?t=3259
Third post...from Andrew himself.
Post by CVH » Sun Sep 15, 2019 5:49 pm
the formula for the arc lenght with degrees and radius is:
angle x pi x r / 180 e_ugeek
An 180 degree arc with diameter 1 has an arc lenght of 180 x pi x 1/2 / 180
What reduces to pi / 2.
Nothing wrong with that! :wink:
A full circle has 360 degrees or 2pi rad.
I'll hope for you that 180 degree is then equal to pi rad.
or 3.14159...rad
