Check QCAD version from CLI
Posted: Fri Jul 19, 2019 3:14 pm
Hi there!
Is there a way to check the QCAD version from the CLI? Something like:
Or...
I am trying to add a check on my batch routines to see if the local qcad distro is updated to the correct version, or prompt the user to update if needed.
Thanks!
$ qcad -v
$ qcad -no-gui -allow-multiple-instances -autostart -v
Thanks!
