Hidden lines
mprocars
Hidden lines
Post by mprocars » Mon Jul 08, 2019 10:26 pm
OK guys I'm just starting out with CAD so bear with me. I've been a machinist for over 30 years and have drawn everything by hand. First attempt at CAD and I'm trying to draw a simple 1-2-3 block with holes in it. 3 view orthographic projection no layers. How the hell do you draw hidden lines (dashed line to represent hidden feature) for the holes?
Re: Hidden lines
Post by andrew » Mon Jul 08, 2019 11:18 pm
In CAD, you'd use layers for that. Please have a look at:
https://qcad.org/en/tutorial-working-with-layers
Please refer also to the QCAD e-book chapter about layers and attributes.
Re: Hidden lines
Post by Husky » Mon Jul 08, 2019 11:18 pm
Hi - welcome to the QCAD Forum.
... no layers.
I would recommend to work with layer - that is a common standard and if you are getting familiar to that technic it is very convenient to work with it.
This is a screenshot of my standard layer template which is used for every new drawing. To get an idea about layer and how to set them up please have a look at this tutorial:
mprocars
Re: Hidden lines
Post by mprocars » Tue Jul 09, 2019 9:54 pm
Thanks guys! I'll give it a try tonight.
