Importing SVG Tables text missing
- Active Member
A very basic Inkscape Table with Text does not import correctly in QCAD. The table borders are imported but not the text. Any ideas? I would like to annotate my QCAD DXF blueprints and thought i could use importing svg from Inkscape for formatting. Attached is the svg.
- TableInkscape.svg
- (58.24 KiB) Downloaded 387 times
Re: Importing SVG Tables text missing
SVG import is currently restricted to geometry (lines, arcs, circles, ellipses, paths).
- Active Member
Okay Thanks.
