How do I set the measurement value manually?
MUSHDesign77
Post by MUSHDesign77 » Tue Jun 18, 2019 5:25 pm
I'm used to Vecorworks and there I could just set the measurment value with the TAB button. Really easy and a great function. Now, whilst drawing and working with the measurements I'm loosing too much time with adjusting the mesurement value. Really annoying. Like, when I want 7,5CM it gets stuck on 6,8 CM and just won't go to 7,5...and I'm just waisting my time...
Is there any way to adjust this in the property editor? Any way to freely typ in the Measured Value in the Specific Properties? Now, I can't, it's grey...
Thank you so much!
Marouscha
Re: How do I set the measurement value manually?
Post by andrew » Tue Jun 18, 2019 5:50 pm
Hello.
Please clarify:
By "measurment value" do you mean the label of a dimension entity? Or the length of a line or something else?
Thanks.
