I'd like to be able to export a DWG through my custom script file (-autostart). I'm trying to use the BitmapExport.prototype.exportBitmap method but I'm getting the following error:
Warning: RScriptHandlerEcma::eval: script engine exception: "TypeError: Result of expression 'view' [null] is not an object."
I assume it's because I'm instantiating a document and documentInterface as follows:
var doc = new RDocument(new RMemoryStorage(), new RSpatialIndexNavel());
var di = new RDocumentInterface(doc);
and I assume that that's why there's no view instantiated.
Can you please share the code inside Dwg2Bmp.js so I can see how to do it properly? or rather can you advise on how to resolve this error?
Export to BMP from script file
Re: Export to BMP from script file
To attach a view (off screen):
var scene = new RGraphicsSceneQt(di);
var view = new RGraphicsViewImage();
view.setScene(scene, false);
Worked. Thanks.
