Export text file from ECMAScript routine
garciadelcastillo
Post by garciadelcastillo » Tue Jun 04, 2019 11:12 pm
Hi there!
Question: is the possibility of writing a plain text file to the system with the ECMAScript API for a custom CLI script?
Scenario: say I am writing a processing tool to perform a batch geometry operations on a set of files. I want to be able to save the modified file, which is straightforward through the documentInterface.exportFile() function. However, I want to generate an additional .log file with the same name, with a breakdown of the modifications on that file. How can that additional, plain text file be written to disk? Since it looks like the ECMAScript interface is not implemented with Node.js, none of its file system APIs are present...
Thanks a lot!
Re: Export text file from ECMAScript routine
Post by andrew » Tue Jun 04, 2019 11:17 pm
You can use the extensive Qt API. Have a look at:
https://github.com/qcad/qcad/blob/maste ... tExport.js
garciadelcastillo
Post by garciadelcastillo » Wed Jun 05, 2019 12:15 am
Ooooh, I see... So the full Qt API has an ECMAScript mirror...? That is sooo interesting...
Wonderful, thank you Andrew!
