QCAD API get coordinates and MergeDrawings.js
sperez
Post by sperez » Thu Apr 25, 2019 4:47 pm
Is it possible to know the coordinates of the bounds of a dwg and the center of it ? We have a big city cad map splitted on a lot of mini-maps and we want to know via a script the center and the bounds in coordinates of this maps
And a second question : Is it possible to get access to the source code in a pro version of MergeDrawings.js in order to know how to join these files in one file in my own script.
Thanks in advance
Santiago Pérez
Re: QCAD API get coordinates and MergeDrawings.js
Post by andrew » Thu Apr 25, 2019 6:51 pm
Yes, that's possible.
// the bounding box of a drawing document (doc):
var bbox = doc.getBoundingBox();
// center of bounding box:
var center = bbox.getCenter();
Sources for MergeDrawings:
https://github.com/qcad/qcad/tree/maste ... geDrawings
sperez
Post by sperez » Tue May 07, 2019 9:44 am
Thanks a lot . It works perfectly.
