Adjusting opacity of solid fill?
Qcad 3.21.2.0; Win10Pro64. Is it possible to vary the opacity of a solid fill? I'd like to lightly color an area of my drawing without blocking out what is under this color. Some of the entities are color filled themselves, so putting this desired light coloring on the bottom layer doesn't really do what I want. Thanks.
Re: Adjusting opacity of solid fill?
No - not in the current version of QCAD.
Idea / Workaround?
You can control the opacity and size of an bitmap.
Create a bitmap in the desired color, load it in your drawing and adjust position, the size and the opacity as you need it.
Interesting idea. I'll play around with it. Thanks.
