dwg2bmp: transparent background
Post by andrew » Thu Jan 10, 2019 10:24 pm
From a QCAD user:
How to I make the bitmap background transparent when creating a bitmap using dwg2bmp?
Re: dwg2bmp: transparent background
Post by andrew » Thu Jan 10, 2019 10:25 pm
You can set the background using the -b switch:
dwg2bmp -b transparent -f -o out.png in.dxf
Note that not all bitmap formats support transparency. If you need a transparent background, PNG is the recommended output format.
