Insertion point library parts
olleb61
Post by olleb61 » Fri Sep 07, 2018 6:03 pm
I have done a couple of items that i have saved as library item
but when inserting them the insertion point is not a part of the item
i would like to choose a specific point of the item or corner for that
any idea to fix it
Re: Insertion point library parts
Post by Husky » Fri Sep 07, 2018 8:28 pm
when you create a Block / Library Item QCAD will ask you for a Reference Point for this item. Now is the moment to choose a Reference Point which will work best for you. For the best accuracy use the QCAD Snap tools to determine the Reference Point.
When you later insert this item it will be hooked to the Mouse Pointer at this reference point. During the inserting process you have the options to flip, scale, rotate etc. the item BUT you can't change the actual Reference Point.
In the case that the Reference Point is not working for you at all then you can change it with a right mouse click on the item in your Library Browser - choose Edit.
The Reference Point is located at Absolute Zero (the Red cross). Just move the item and make sure that your new reference point match the red cross.
Save it to the Library and you are ready to go. :wink:
olleb61
Post by olleb61 » Sat Sep 08, 2018 10:08 am
Edit move and place my instertion point at absolute zero is the answer
