Dimension lines using center or middle point
Panchdara
Post by Panchdara » Sun Jul 22, 2018 6:44 pm
Hi again. I am trying to draw a dimension line from one endpoint to the middle of another line segment. I have given link to the video. If I use center or middle of one point the dimension disappears.... am I missing something?
Best
Hugh
Win 10
QCAD 3.21.2
Video_2018-07-22_183410.wmv
(1.18 MiB) Downloaded 332 times
Windows 10
Re: Dimension lines using center or middle point
Post by Husky » Sun Jul 22, 2018 7:17 pm
QCAD is trying to do what you told QCAD. Snap to the "Center" is after the second point still active. Change the Snap to "Free", or what ever is needed, and it will work.
BTW: Maybe a good idea to get familiar with the "Auto Snap" settings in QCAD - it will save you a lot of clicks. :wink:
Panchdara
Post by Panchdara » Sun Jul 22, 2018 7:25 pm
Many thanks Husky. Now I see the light!!!.... Got it! I have done most drawing using deliberate snap points. I feel a little embarrassed now :oops:
Makes total sense. I'll use Auto more as well.
And thanks for your very prompt response.
Very best
Windows 10
Post by Husky » Sun Jul 22, 2018 8:09 pm
You're welcome.
No reason for that! All of us had experienced situation like that one. :wink:
