Is it possible to lock/unlock blocks?
dfriasb
Senior Member
Post by dfriasb » Thu Dec 21, 2017 5:43 pm
Just like layers. I don't see the way.
Thanks,
David
Re: Is it possible to lock/unlock blocks?
Post by Husky » Thu Dec 21, 2017 6:17 pm
dfriasb wrote:Just like layers. I don't see the way.
Thanks,
David
No, you can't lock a block solitary. But a block on a locked layer is certainly blocked too.
How ...
One of multiple possibility's is to lock/unlock a layer directly in the layer list.
