Open files from the command line (bash/linux)
jvalencia
Post by jvalencia » Sat Dec 16, 2017 8:21 pm
I try with "qcad file.dxf" but nothing works.
Also, "qcad --help" don't show anything.
How can I do it?
QCad Pro 3.18
Thanks.
lphilpot
Re: Open files from the command line (bash/linux)
Post by lphilpot » Sat Dec 16, 2017 8:42 pm
That should work. My (Linux) desktop file does this:
/opt/qcad/qcad /home/len/Documents/QCAD-default.dxf
...which is essentially the same thing you indicated.
Does QCAD not launch at all, or does it launch but without loading your file?
What OS are you on?
Len
Post by andrew » Mon Dec 18, 2017 10:03 am
To show usage info:
./qcad -h
If it does not work, you might not be in the right directory.
