Point display in paper space
dfriasb
Senior Member
Post by dfriasb » Fri Nov 24, 2017 3:36 pm
Hello all,
Is there any way to print points like they look in model space? I use mode 2 (cross) to draw in model space, but I always print a dot in paper space. I would like to print a cross as well if possible.
Thanks! Best regards,
David
Screenshot from 2017-11-24 15-33-35.png (35.4 KiB) Viewed 1874 times
Re: Point display in paper space
Post by andrew » Fri Nov 24, 2017 4:16 pm
No, these are for display only (pixel sizes). If you need to print something else, I'd recommend using blocks.
dfriasb
Senior Member
Post by dfriasb » Fri Nov 24, 2017 4:38 pm
Thanks for your super fast answer Andrew!
Yes, I'll do it with blocks.
Have a nice weekend,
David
