Not sure if I'm missing something but... I prefer to work in draft mode and would like all new drawings to be automatically opened in draft mode... is there a setting for that or must I always go View->Draft Mode (D, F)?
New drawings in draft mode.
Windows 10
Re: New drawings in draft mode.
Not to my knowledge. Maybe you like to post a Feature Request below:Panchdara wrote:... is there a setting for that or must I always go View->Draft Mode (D, F)?
http://www.ribbonsoft.com/bugtracker
Additional thought:
I would also appreciate if the "Draft Mode" Status would be saved with the drawing like "Screen-based Linetypes" and "Anti-aliasing".
Thanks Husky. I did that but made mistake of flagging as a "bug"... then Andrew (I presume) set it to the correct flag as "feature request". The only reason I mention this is because it's very reassuring that these requests are being looked at on a very timely basis. QCAD support is one of the very best.
Windows 10
