Hello all,
Is it possible to filter entities by Custom Properties? (I mean the ones user can add at the end of the Properties Toolbar)
If not, I guess it is possible using some script, is it?
Thank you. Best regards,
David
Custom property filter
Re: Custom property filter
Hello, can you please ellaborate? Filter in what sense? For selection (as in View > Selection Filter)? Thanks.
- dfriasb
- Senior Member
Yes, I mean using View > Selection filter. I don't see any "Custom Property" option in the Selection Filter "Property" menu, so I guess it is not possible right now, at least without scripting specific command to do that.
Regards, David.
Regards, David.
- Screenshot from 2017-06-16 16-09-50.png (9.72 KiB) Viewed 5795 times
Yes, that's correct.dfriasb wrote:I don't see any "Custom Property" option in the Selection Filter "Property" menu, so I guess it is not possible right now, at least without scripting specific command to do that.
I've added a feature request at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1596
- dfriasb
- Senior Member
Thanks again Andrew!
