[solved] How can I create a polyline from a hatch contour?
dfriasb
Senior Member
Post by dfriasb » Wed Mar 08, 2017 1:06 pm
I have a hatch, and I want to get its contour as a polyline. Is there a fast way to do it (not drawing the polyline point to point)?
Re: How can I create a polyline from a hatch contour?
Post by andrew » Wed Mar 08, 2017 1:46 pm
1. Use the property editor to change the hatch to a solid fill (set property "Solid" to "Yes").
2. Select the solid fill.
3. Modify > Explode
dfriasb
Senior Member
Post by dfriasb » Wed Mar 08, 2017 1:58 pm
Fantastic!!!
Thanks a lot!
David
