Snap to Insertion Point of a Block
- dfriasb
- Senior Member
I know you can snap to insertion point of a block like any other reference point, but I never saw the option to snap ONLY to insertion points of blocks. Is that possible?
Re: Snap to Insertion Point of a Block
Not that I know of. May I ask you what would be the benefit to have an isolated snap to the Block reference?dfriasb wrote:I know you can snap to insertion point of a block like any other reference point, but I never saw the option to snap ONLY to insertion points of blocks. Is that possible?
- dfriasb
- Senior Member
If you want to draw a line starting in the block reference point, for example:
- I draw this line to keep origin (Insertion point) of the block, so I can edit it in place (with the rest of the drawing)
- Screenshot 2017-03-07 09.38.33.png (255.17 KiB) Viewed 3055 times
- I try to start a line in the Insertion Point, but it's impossible. Even if I Snap to Reference, it is had to know if I'm Snapping to Insertion point or other.
- Screenshot 2017-03-07 09.37.53.png (260.72 KiB) Viewed 3055 times
- WC block. You can see where the Insertion (Reference) point is located
- Screenshot 2017-03-07 09.37.06.png (265.58 KiB) Viewed 3055 times
Hi David - thanks for this explanation. I would not recommend this kind of annotation but I'm not an Architect.
