How can I change the area shown in the output with dwg2bmp?
dwg2bmp: auto zoom / area shown in output
From a QCAD user:
Re: dwg2bmp: auto zoom / area shown in output
dwg2bmp by default performs an auto zoom to find out the extents of the drawing.
If the output appears to be smaller than expected or there are large margins, it is likely an indication for small entities far away from the main drawing area. Delete those entities to fix the auto zoom behaviour.
Alternatively, you can also specify a window to zoom to:
dwg2bmp -w x,y,width,height
