Inch dimension markers in row/column fields ?
Markz
Post by Markz » Sat Jan 30, 2021 6:40 pm
Am I right that the only way to make a row/column array in QCAD is with the block properties?
In the block properties, the row/column indicators are populated by inch dimension marks. I think this is a bug, but perhaps they have some other use?
Re: Inch dimension markers in row/column fields ?
Post by Husky » Sat Jan 30, 2021 6:58 pm
If I recall that correctly that was a bug in a previos QCAD Version. It was fixed!
Which QCAD Version on which OS you are using?
Markz
Post by Markz » Sat Jan 30, 2021 7:14 pm
Linux.
QCAD 3.25.2
Post by Husky » Sat Jan 30, 2021 7:23 pm
Linux.
QCAD 3.25.2
Thanks. I can't reproduce that with a QCAD 3.25.2.0 version on a Win10 OS. Could you post the file (dxf) too? Thanks.
Markz
Post by Markz » Sat Jan 30, 2021 7:44 pm
I just produced that example on the fly, so I don't think it has anything to do with the drawing per se. But, for what it's worth, I've recreated the example and attached.
If I boot into Windows later, I'll try the test there to see whether it's different.
Thanks!
qcad-circle-block-dims-test.dxf
(101.6 KiB) Downloaded 410 times
Post by Husky » Sat Jan 30, 2021 8:38 pm
Thanks for the dxf!
... so I don't think it has anything to do with the drawing per se. But, for what it's worth,
It is a combination of settings. This effect was only shown when the dim settings are adjusted to Architectural or Engineering and the Drawing Unit is Inch. That is why I have ask for the drawing. :wink:
As I said - this bug is already fixed. Please download the newest snapshot (3.25.2.9) of QCAD or wait for the next stable QCAD version.
Note: Snapshots are packages with the current development version of QCAD. Snapshots should be considered unstable and are not intended for production use.
