Paint Properties, copy linetype scales
Draffy Duck
Post by Draffy Duck » Sat Jan 25, 2020 9:45 pm
I regularly adjust linetype scales on hidden, centreline and phantom lines to achieve the best appearance on the drawing when printed. I note the Paint Properties feature copies all the attributes of the chosen line but does not copy the scale. I have to change the scale of each line, even after 'painting'. This copying all Properties is something AutoCAD does. I know I could change the line to Hidden2 etc. and tick the 'scale lines' box in Drawing Properties but that is not always successful- copying properties is a quick and useful way of achieving the required result. Could that tweak be incorporated into a future update. Thanks.
QCAD Pro 3.24 Windows10. AutoCAD user for 30 years, happy convert.
John Hyslop
Re: Paint Properties, copy linetype scales
Post by John Hyslop » Sun Jan 26, 2020 1:20 am
Hi Draffy
I'm also a convert 30+ years with AutoCad and very happy with Qcad ..
You can submit a bug or feature request see link..
Andrew is very good at getting on top of things as you can see updates are very regular 😁
Please register here and post your requests.
Cheers
John Hyslop
