Set min. line thickness when using dwg2pdf
Posted: Mon Apr 22, 2019 4:08 pm
by sistemas.caw
Have any way to set min. line thickness when using dwg2pdf script?
Att,
Rhodolfo Novochadlo.
Re: Set min. line thickness when using dwg2pdf
Posted: Tue Apr 23, 2019 9:40 am
Yes, from dwg2pdf -h:
-w, -min-lineweight=LW  Set minimum line weight to LW drawing units
Posted: Tue Apr 23, 2019 3:22 pm
by sistemas.caw
Andrew,
Thank you very much for your quickly reply,
I tried to use -w parameter. But, for some files this parameter have different behaviours. Look attached files.
PDF1 was generated using CAD1 with command (dwg2pdf.bat -a -c -d -f -n -l -w 0.5 -fs romans standard -fs romand standard -o "C:\Temp\a\2pdf\PDF1.pdf" "C:\Temp\a\2pdf\CAD1.DWG")
PDF2 was generated using CAD2 with command (dwg2pdf.bat -a -c -d -f -n -l -w 0.5 -fs romans standard -fs romand standard -o "C:\Temp\a\2pdf\PDF2.pdf" "C:\Temp\a\2pdf\CAD2.DXF")
I think that -a parameter is conflicting with -w
Posted: Wed Apr 24, 2019 9:47 am
Yes, the value is in drawing units, not paper units. 0.5mm in drawing units are wider when zoomed in.
This might change in a future version to define a minimum lineweight independent of the zoom level.
Posted: Thu Apr 25, 2019 5:12 pm
by sistemas.caw
Andrew, thank you very much for your help.
Do you know when is the prevision of QCad release with this improvement? This is very critical for my application and if take a long time I will need to study other solution for me.
regards,
Rhodolfo Novochadlo
Posted: Thu Apr 25, 2019 6:56 pm
It will be in the next snapshot release, usually released within a few days.
Snapshot releases are announced at:
https://www.qcad.org/rsforum/viewforum.php?f=16
Posted: Thu Apr 25, 2019 9:05 pm
by sistemas.caw
Thank you very much Andrew, I will wait.
Posted: Thu May 23, 2019 10:49 pm
by garciadelcastillo
Same problem here with "dwg2bmp", did this feature make it to 3.22.1?
Posted: Fri May 24, 2019 8:46 am
Yes.
